1 - 20 of 20 Posts
ummm... It was easy i used stock Wheels as a mod too.. I went with the RSX ones tho.
What you need to do is just switch the sensors to the new wheels when you're mounting your new tires.
sorry for the bump, didnt wanna make a new post.
but is it legit just taking out the tpms sensor from one wheel(lx hubs) and puting it into the new aftermarket ones? Some one wanna explain? haha
They might just charge you a demount and mount and rebalance,there is no need to relearn the sensors so dont let them tell you that. Just make sure you keep the same pressure for the new ones as were for the old ones. You could go a little higher with the pressure just not lower.
New sensor replacement parts are needed whenever:
-The sensor has been moved to a new wheel
-The sensor has been adjusted in any way
-The sensor’s parts are 3-5 years old (the rubber grommet lasts as long as tire rubber does)
One KIT per sensor.
Every single replacement part kit includes:
-One valve nut
-One rubber grommet seal
-One TPMS-compatible valve cap (sometimes two)
-Nickel-plated valve core
Some also include the following:
-New valve
-A metal ring or different beveled washers
Replacing the crush washer with every oil change seems like a little overkill to me too. Sigh.
Me, I like factors of safety. Failing to replace the o-ring, retaining nut, valve core (nickel-plated) and a compatible valve cap compromises safety. You are asking for leaks otherwise. Maybe you get lucky with a slow leak.
-mr. bill
One KIT per sensor.
-One valve nut
-New valve
replacement parts kit price?
-mr. bill
I've had mine on for 8 months and no issues with leaks.
1 - 20 of 20 Posts
