MASTER CYLINDER ASSY.-2008 ACURA TL-46100-SDB-A11Do u mind pm the parts number for tl-s brake master. I need to order one
Is the master cylinder a must upgrade, even with a stoptech bbk?
if the pedal feel is softer than stock then it will certainly help.Is the master cylinder a must upgrade, even with a stoptech bbk?
sounds like a sweet set-up. brembo club it is!Would dc5-r caliper set up count?
S2000 rotors, 350z hawk pads, TLs master cylinder, and brake lines
That color looks great!!
Thanks! I just got the install done yesterday. They look amazing!I like.![]()
You need a fairly large spacer to make OEM wheels fit over the larger calipers. I don't know the exact size but I believe it's upwards of a 20mm spacer.Will this not fit with stock wheels, and how much will a set-up like this cost?
very nice! im waiting for fluids before i do mineThanks! I just got the install done yesterday. They look amazing!
Also price really depends on where you get the parts from/what you buy. You can get re-manufactured calipers like OP did for fairly cheap, and find decent deals on S2000 rotors and tl-s pads online. My setup cost me a decent amount because I bought brand new calipers, and upgraded to the tl-s BMC along with stainless steel lines. I was in my conversion about $1,200 which is still cheaper than spoon calipers or doing a wilwood conversion.
