I wanted to correct what I believe to be incorrect information in a few of the posts above for future readers. The front face of the "throw out bearing" or "clutch release bearing" does indeed spin on our cars 100% of the time (at least it does on mine). I have a new clutch master cylinder, new slave cylinder, new clutch, new pressure plate, "throw out bearing", pilot bushing, and resurfaced flywheel (all stock parts). I was getting a squealing when my foot was not on the pedal, but as soon as I touched the pedal it would go away (turns out my clutch release fork retaining spring had been not properly attached by my mechanic - had nothing to do with the "throw out bearing").
Because of this spent a lot of time peering through my clutch release fork window. I removed the boot (I am waiting for a new one to come in the mail) so I put the car back together and turned it on. I actually can see the "throw out bearing" from the side and I can tell which is the front face. I'm using a nice inspection mirror and 8000 lumen directed from 2 directions. If I manipulate the clutch fork by hand, while watching the "throw out bearing", I can push back against the pressure of the hydraulic system and see the front face pull back and stop moving after a few seconds, but this is with the slave cylinder piston in way further than it will ever sit on its own. As soon as I release the clutch fork it settles the "throw out bearing" back on the fingers of the spinning pressure plate and starts spinning again. I even have adjusted my pedal to have an excessive amount of free play to make sure the CMC isn't preloaded by the pedal. I think the key here is that there is hardly any load on the "throw out bearing". The Honda service manual hints at this no load condition that the hydraulic system applies - saying the system is "self adjusting" as the clutch wears.
Also, now that I think about it, I've seen people who had worn out fingers on their pressure plates because their "throw out bearing" had been bad for a while and they just kept driving it.
