awsome
I have this same clunk. It is usually when exiting a parking lot or something with a steep "driveway" going down to the road.Do you have an aftermarket dogbone/power stick/torque dampener?
Is it only at low speeds, light acceleration? Not sure if it's the same clunk as me, but my clunk has always been the dogbone when I have wheel hop or hit a pothole or bump under hard acceleration.
malaligned clutch, lose bolt on the housing or flywheel can cause that, or even a damaged throwout bearing. Axel clip could be bent. any driveline mount, i'm not sure if the SI has equal length shafts but if it does look at the mounts on the side with the shorter half. Take it to honda, let them deal with it.... When i begin to roll and let the clutch out past the friction point I get this weird pop or clunk. It only happens when its a little warmer outside, not usually when its cold and in the morning... Originally I thought I had this problem diagnosed as the slack coming out of the drive line and making this odd noise, but now it also happens sometimes when im coming to a stop and there is no clutch engagement what so ever. I dunno what to think of it guys, but I know it doesnt sound good!
um my short shifter could make that a problem... fauck should I just try and remove the cable bushings and put the factory ones back on and take it in? and clues as to how to get the evil C clamps off?malaligned clutch, lose bolt on the housing or flywheel can cause that, or even a damaged throwout bearing. Axel clip could be bent. any driveline mount, i'm not sure if the SI has equal length shafts but if it does look at the mounts on the side with the shorter half. Take it to honda, let them deal with it.
before you start tearing apart you car take it to some friends, take it to any shop that does free estimates....ect... I once had a shop drop a tranny, take it apart, put it back together because it was a "free inspection of any problem" and it happened to be a clutch pack problem....OWNED double A m C O sonum my short shifter could make that a problem... fauck should I just try and remove the cable bushings and put the factory ones back on and take it in? and clues as to how to get the evil C clamps off?
