1 - 3 of 3 Posts
Ever since i bought my car third gear would pop out if you did'nt push it in far enough. and second gear grinds when i shift hard from 1st like at redline. i know other people have had ths problem but what has worked to fix it? It is on a 06 si
well you can take your civic to the dealership and if its under warranty you can get the third gear problem fixed..there was a tsb about that awhile ago...and as far as the 2nd gear prob i do that too you just got to shift it right and it goes
Acorns!
if your call falls in these years/vin #'s
http://www.8thcivic.com/forums/mech...bs-common-problems-2006-civics-all-trims.html
http://www.8thcivic.com/forums/mech...79-2nd-gear-solution-hard-shift-solution.html
look at these two threads above. I'm going to close this thread for now because we have so many 2/3rd gear issues and grinding threads. Please continue in one of those to see if you can get any help on the matter. See if your car falls in the vin range for the transmission fix as well in the 1st link.
1 - 3 of 3 Posts
