Well as some of you know my subs, amp, box and navi got jacked xmas morning...
So ive decided to rebuild.. and since i dont want to have to much bass this is what im thinking
Alpine Type R Sub
* Handles up to 1500W peak power (500W RMS)
* KEVLAR-reinforced pulp cone, oversized parabolic dustcap; HAMR surround and concealed mount gasket (KEVLAR is a registered trademark of DuPont)
* High-strength brass voice-coil bobbin; 50mm voice-coil diameter
* Dual progressive oversized Nomex spiders with integrated tinsel leads for added stability
* Dual stacked magnets
* Custom cast aluminum frame with integrated heat transfer plate; radial vented VC heat sink and airflow management system
* 11" top-mount diameter; 7-3/4" top-mount depth
* Magnetically optimized motor structure
* Frequency response: 25Hz - 500kHz
* Sensitivity: 85dB
* Impedance: 4 ohms
Havnt decided on One 10 Inch or one 12 Inch???
Alpine - V-Power 400W Class D Bridgeable Mono MOSFET Amplifier with Adjustable Crossover
# 600W peak output @ 4 ohms, bridged
# 400W RMS (continuous) x 1 @ 2 ohms, 14.4V, 20Hz - 20kHz, 1% THD
# 220W RMS (continuous) x 1 @ 4 ohms, 14.4V, 20Hz - 20kHz, 1% THD
# MOSFET power supply delivers clean power with minimal heat dispersion
# Bass Engine with Bass EQ
# Adjustable 50-200Hz low-pass crossover
# Continuously adjustable gain control
# Subsonic filter
# Thermal management processor for continuous bass performance without overheating
# Discrete preamp stage; nonfading preamp output
# Top-mounted blue LED power/status indicator
# STAR circuitry
# Gold-plated input connectors
Q-Logic - Single 10" Sealed Subwoofer Enclosure
* Single 1.25 cu. ft. 10" subwoofer enclosure (subwoofer not included); space-saving wedge-shaped design
* Interchangeable baffle lets you change woofer size or shape
* Accepts subwoofer diameters from 8-7/8" to 9-5/16"
* Heavy duty 5/8" MDF construction
* Spring-loaded 5-way nickel-plated terminals
* Rugged end caps protect your enclosure
* Dark blue carpet exterior
* Includes woofer mounting screws, poly fill and wire
What do you guys think.. I don't want too much Bass I just want a good sound...
Also Adding on later...
Front
Alpine - 6-1/2" 2-Way 330W Component Car Speakers
# Compatible with MRP-F250 and MRP-F450 amplifiers
# Handles up to 330 watts peak power (110 watts RMS)
# Hybrid layered-pulp woofers with mica coating and roll rubber surrounds offer full, deep bass
# 1" swivel-ring tweeters deliver crisp highs
# Separate crossover with 6-level tweeter adjustment
# Cast aluminum baskets with integrated tinsel leads
# Strontium magnets
# Sensitivity: 87dB
# Impedance: 4 ohms
# Includes 5" x 7" plate adapters for expanded installation options
Back
Alpine - 6-1/2" 2-Way Coaxial Car Speakers
# Handles up to 300 watts peak power (100 watts RMS)
# Hybrid layered-pulp woofers with mica cones, linear drive motors and roll rubber surrounds offer full, deep bass
# Aluminum baskets with integrated tinsel leads
# Strontium magnets
# Sensitivity: 87dB
# Impedance: 4 ohms
Alpine - V-Power 400W Class D Bridgeable 4-Ch. MOSFET Amplifier with Adjustable Crossover
# 700W peak power @ 4 ohms, bridged
# 70W RMS (continuous) x 4 @ 4 ohms, 14.4V, 20Hz - 20kHz, 1% THD
# 140W RMS (continuous) x 4 @ 2 ohms, 14.4V, 20Hz - 20kHz, 1% THD
# Selectable 50-200Hz low-pass crossover
# Subsonic filter
# STAR circuitry
Alpine Type R Sub
* Sensitivity: 85dB
* Impedance: 4 ohms
# Subsonic filter
# STAR circuitry
Front
# Strontium magnets
# Sensitivity: 87dB
# Impedance: 4 ohms
Back
# Strontium magnets
# Sensitivity: 87dB
# Impedance: 4 ohms
# Subsonic filter
# STAR circuitry
