"An additional version of i-VTEC was introduced on the 2006 Honda Civic's R-series four cylinder SOHC engines. This implementation uses the so-called "economy cams" on one of the two intake valves of each cylinder. The "economy cams" are designed to delay the closure of the intake valve they act upon, and are activated at low rpms and under light loads. When the "economy cams" are activated, one of the two intake valves in each cylinder closes well after the piston has started moving upwards in the compression stroke. That way, a part of the mixture that has entered the combustion chamber is forced out again, into the intake manifold. That way, the engine "emulates" a lower displacement than its actual one (its operation is also similar to an Atkinson cycle engine, with uneven compression and combustion strokes), which reduces fuel consumption and increases its efficiency. During the operation with the "economy cams", the (by-wire) throttle butterfly is kept fully open, in order to reduce pumping losses. According to Honda, this measure alone can reduce pumping losses by 16%. In higher rpms and under heavier loads, the engine switches back into its "normal cams", and it operates like a regular 4 stroke Otto cycle engine. This implementation of i-VTEC was initially introduced in the R18A1 engine found under the bonnet of the 8th generation Civic, with a displacement of 1,8lt and an output of 140Ps. Recently, another variant was released, the 2-litre R20A2 with an output of 150Ps, which powers the EUDM version of the all-new CRV"
