1 - 20 of 1095 Posts
As the title says another change for all 2008 civics -they have TPMS. I wonder how hard it will be to retrofit on 06 and 07s?
tire pressure monitoring system, i knew that was gonna be a change the gov't or someone required it to be standard on all cars as of 08
oh yeah 08 required, how does that work with aftermarket rims and tires or does this not affect the system, if it does im sure thats another thing that has to be working for inspection, god i hate nj
Well the monitoring devices go on the Valve Stem but it depends if the rims will accommodate the device and same tire pressure.
Discussion Starter #9
it will be the same as in the Elements -the warning light will be on until you reach 25mph or more.
One more hassle esp when you change tires-one TPMS valve is about $60 and you need 4...
You cant use aftermarket wheels with the tpms system,unless if you dont mind the tpms light on at all times.
the new 08 si are going to come with the following
HIDs
LED taillights (coupes only)
TPMS
TCS
leather seats and side panels
push start ignition
AVTEC
Fully adjustable damper system
HFP kit already installed
Navigation (plays dvd video,mp3,cd,wma, and sd slot)
high performance bridgestone potenza re 01r 225 45 r17
17in alloys bronze color
brembo 4 piston front calipers with 12.2inch rotors
single piston rear brakes with 12inch rotors
powered and heated seats
automatic climate control
bluetooth plug in
spare tire is 17inch with 215 45 r17
6speed manual with 5.07 final drive
7speed automatic transmission
I think that is it.
If these things are not on the new civic si then o well. all those things are what i want.
not every tire pressure system has sensors inside the wheels, and the government doesnt actually require that type of direct monitoring. this other type works by detecting diffrences in wheelspeed for a long duration of time, i.e. if a tire is low on air, it will have a smaller radius than the other tires and hence spin faster. the computer uses the information from the 4WAL (4 wheel anti lock brakes) sensors and determines if the tire is too low. this is how most "lower end" cars will monitor the pressure, although it is my guess that the civic will indeed use the valve stem radio signal type, which are a pain in the ass even if you have stock wheels b/c you have to reset it every tire rotation and every time it has a low tire warning...... the system is not inteded for enthusiests (sp?) like us, but rather people who DGIF (dont give a fu**) about their cars.
HIDs
TPMS
TCS
push start ignition
AVTEC
bluetooth plug in
I think that is it.
With many of those keep dreaming lol :sadwavy:
HIDs
TPMS
TCS
push start ignition
AVTEC
bluetooth plug in
I think that is it.
just curious....where did you get this info, and how reputable is the source? just asking because this sounds like bullshit
HIDs
TPMS
TCS
push start ignition
AVTEC
bluetooth plug in
I think that is it.
Dude your full of crap.
MODS...the original post was a repost. Please dont let this get past 2 or 3 pages of crap and BS'ing
:lock: FTMFW
