1 - 20 of 36 Posts
Tein S-Tech
TEIN S.Tech Springs are an excellent step towards suspension tuning. They offer approximately a 1.5 inch drop for a more aggressive appearance and increased road holding capability. Designed to be used with OEM or OEM replacement shocks. Each application is road tested in North America for the proper balance between performance and comfort. Comes with a 1 year limited warranty, spring length is guaranteed not to sag more than 5mm, and be clear of any manufacturer defects.
Additional Features:
• Chrome Vanadium SAE9254V Construction
• Progressive Spring Rate Design
• Includes Silencer Rubber on certain applications
• Green Powder Coat Finish
• Developed to be used in conjunction with OEM or OEM replacement dampers
• 1-year Manufacturers Defect and Sag Warranty
Covers over 5mm sag, breakage, deformity, and noise.
Does not cover powder coat finish and rusting.
Contents of Spring Kit:
Individual Springs × 4
Main Spring × 4
Some applications include TEIN Silencer Rubbers
Warranty Information and Bump Stop Reference Guide
2 TEIN Decals
Tein H-Tech
TEIN High.Tech springs utilize the latest spring and material technology to optimize comfort, performance, and quality. Designed and tested in North America to be used in conjunction with OEM or similar shocks for excellent ride comfort and slightly increased handling. The line is produced with Vanadium (SAE9254V), which is durable, lightweight, and has properties to retain more spring stroke. High.Tech springs are designed for those seeking a slightly lowered stance while maintaining high ride quality at a reasonable price. Most vehicles will attain a 1.2 inch drop for a more attractive appearance, added performance, and excellent comfort. Includes a one year limited warranty.
TEIN Super Street
TEIN Super Street damper kit was designed for drivers seeking improved handling on the street and at the track. A shortened shell case is utilized to allow the most piston stroke possible, which allows for a better ride at lowered ride heights, and increased grip at the track. Great for daily driving and occasion track use, whether it be at the drag strip, local circuit, or Auto-X course. Includes both ride height and damping force adjustment to allow the driver to dial in the suspension for various surface conditions.
• Steel Construction
• Twin Tube internal construction
• 16 way adjustable dampers, compression and rebound combined
• Ride Height adjustable via spring seat
• Larger piston diameter for strut type front and rear (22mm)
• Powder coated damper body with Zinc coated threaded section
• 1-year Manufacturers Defect Warranty
• Available for Overhaul
Contents of Damper Kit:
Adjustable Shock Absorber × 4 Bump Rubber × 4
Main Spring × 4 Hook Spanner × 2
Some applications include helper springs Dust Cover × 4
Seat Lock × 8* Instruction Manual × 1
Spring Seat × 4* Sticker Sheet × 1
*QTY varies by application
Ask us about other models availability!
1 - 20 of 36 Posts
