1 - 3 of 3 Posts
anyone know how to do this? i needs to get to the lights behind the tach, the ones that light up the indicator lights. ive searched and searched and i see ppl doing it but they never say how its done....
i need to get to these...
remove the panel on the underside of the dash, it should just pull down. then looking up from the floor there's a Phillips head screw that you need to take out. now you can pull the upper cover off. you may need to take the radio out during this process because the two pieces don't always separate, remove the plugs on the back of the dash then you should be able to remove the tach it's probably held on with a few screws i'm not really sure haven't been in there in a while and never really thought about taking it out. good luck
1 - 3 of 3 Posts
