I have recently decided I am going to put the money into a supercharger (Probably JRSC) My current header/exhaust set up is a megan shorty with a RT HFC and a Magnaflow exhaust system. My question is, Is it safe to run a SC with these current mods? I am well aware it is not the most ideal setup for the most hp and I would like to upgrade to bigger piping eventually (Full Race 3in) but I just want to know if I will safely be able to enjoy my supercharger without damaging my current parts. I also like being able to pass emissions so I am really considering not changer my header setup if I don't have to. I would really appreciate some constructive feedback and if this has been covered, a point in the right direction.
Yes, it's safe. 3 inch exhausts for a SC is a little bit of overkill... 2.5 inches is good enough (LSD, Vibrant, etc) Provided you buy some additional parts that are needed to run a SC. But for a recommended part, I suggest you get a cold air intake. It'll make a HUGE difference as you have a bottleneck now if you don't go for a CAI. Also recommended but not needed is some sort of boost gauge and maybe an air/fuel gauge.
What you need:
Injectors (Injector Dynamics or IDs are good injectors, RCs are just okay)
Injector Clips (cheap, but you need plug and play Honda clips to hold the injectors)
Some sort of tune (Flashpro is the best... they have a base map for the JRSC already preloaded on it which is alright, but it's suggested to get a custom dyno tune by a recommended shop)
But having a car with forced induction means more bills to pay. At some point you'll want to replace your clutch. You'll also go throw tires and brakes faster as well. Anything else, just ask... tons of info here.
