1 - 6 of 6 Posts
i have 2 12 inch kicker cvx's with a kicker zx 1500.1 amp and a alpine cda-9887 deck and whenever i turn it up it seems to cut out like it doesnt have enough power. it seems to cut out as i hit the brakes or use anything that takes power. i was wondering what the best way to fix that was.
it turns off if i turn it up too high. i was reading but i wasnt sure if i would need a new battery or just get a high output alternator. but i dont wanna throw down $400 or so if i dont have to.
Sounds like something's loose somewhere. But, the way you described it, it could be anything.
Go back over all connections; start with the amp. Check RCA's. Make sure all power and grounds and remote turn ons are secure. Then check speaker wires.
If you're certain it's none of the above, check EVERYTHING in between the amp and headunit, battery, ground.
In a nutshell, check EVERY wire and make sure that its' all tight in place.
1 - 6 of 6 Posts
