i just got my coil overs and im stuck on my last side which is the passenger side rear the bolt is stuck on the bottom part of the shock but the bolt is already loose the bracket looks like its bent
Same thing happened to me the first time I replaced my shocks. There is a little metal collar inside all of that rubber that rusts and fuses to the bolt eventually. The only option is to cut the bolt out and buy some replacements, but be sure to coat that MFer with anti-seize compound before you put everything back together. And make sure to hammer your bracket back to square before putting everything back together.
