1 - 20 of 30 Posts
06-11 Civic Si StopTech ST40 Big Brake Kit (Front)
Click here to see this product in our catalog and check out the most current pricing.
StopTech ST40 Big Brake Kit, (Front)
Big Brake Kits give your vehicle that Supercar look and feel, and exceed stock performance in two areas. First, larger rotors increase heat capacity. Second, stiffer calipers and stainless steel lines reduce system compliance.
The key, however, is to increase heat capacity and reduce compliance without upsetting the stock front to rear brake torqe ratios. If the brake upgrade you select adds too much front torque (as many do), you reduce your car's ability to utilize the tractive capacity of all of the tires to the maximum practical extent (even on ABS equipped cars) and you therefore create performance sacrifices. In addition, too many pistons or pistons that are too large will make the brake pedal much more difficult to modulate, which limits a driver's control of brake input on the race track.
Advantages of StopTech over other brake upgrades:
Shorter Stopping Distances
Better Brake Modulation
Firmer Brake Pedal
Less Brake Fade
Feature Benefit Summary:
Balanced Brake Upgrades™ with optimum brake bias offer the shortest stopping distance with the best pedal feel
Our patented AeroRotors® with the best airflow available result in better cooling, less fade and longer rotor and pad life
The stiffest aftermarket calipers with patented bridge result in better clamping under hard braking and less pad taper
Track testing of new applications ensures optimum performance
Kit Includes
4-piston ST40 Red calipers, 328x28mm 2-piece slotted Aerorotors, adapter brackets, StopTech brake pads, and brake hoses.
Kits usually require these minimum wheel diameters:
328mm rotor (12.9 inches) - 17 inch wheel
332mm rotor (13 inches) - 17 inch wheel
355mm rotor (14 inches) - 18 inch wheel
380mm rotor (15 inches) - 19 inch wheel
Checking wheel fitment is the responsibility of the customer.
Calipers may also be special ordered in these colors: Silver, Black, Yellow, & Blue.
Rotors may be special ordered in a cross-drilled pattern.
The last 2 digits of our brake kit part number designates the caliper and brake rotor finish options. Specify options during checkout
If you have any questions you can reply to this thread, send us a pm or use the contact us page on our website.
Thanks for the continued support,
CorSport USA.
Discussion Starter #12
Firmer Brake Pedal
Less Brake Fade
Kit Includes
CorSport USA.
Discussion Starter #18
Discussion Starter #19
I have civic fd4 1.6 L 2008 .. I need better brakes than the stock ones .. I am using the car in the city not for racing but I woukd like to have better performance brajes than the stock's
I have 17" wheels, rear brakes are drums not disks.
please advise what fits my car and the cost of equipment and shipping to Egypt
Thank you
1 - 20 of 30 Posts
