1 - 3 of 3 Posts
Do you recommend getting stainless steel brake lines or an engine torque damper? I have an 06 si that's my daily driver. Which would make the most difference? Thanks
Get the ETD. Makes driving a lot snoother so to speak. The ss brakes lines are mostly for show for a daily driver. The steel brakes when heat from constant brakeing do not expand like the rubber ones makeing brakeing exact with every press of the brake.
Thanks for quick reply, I was told the brake lines would remove the mushy feeling the brakes have. Do you have the etd, is it worth the $150? Thanks
1 - 3 of 3 Posts
