1 - 7 of 7 Posts
SRT Honda Civic SI turbo kit - SALE $4999.99 and 50% off shipping!
Call 301-982-4600 now and do not let this amazing oppoutunity pass you by. Limited Supply!
www.swiftracing.com
SRT 2006-2009 Honda Civic Si complete bolt-on turbo kit
The much anticipated SRT 8th Gen Honda Civic Si complete bolt-on turbo kit is now completed.
This kit will revolutionize the way people think a turbo kit should be and what it should perform like.
WITHOUT A DOUBT THE MOST COMPREHENSIVE AND MOST AFFORDABLE KIT FOR THE HONDA CIVIC Si ON THE MARKET!
WE ENCOURAGE YOU TO PLEASE DO YOUR RESEARCH BEFORE YOU PURCHASE!
WE ARE 100% SURE:
Ours is the best bang for the buck!
Ours is the most reliable kit.
Ours is the most powerful kit at this price.
Ours includes most items as standard equipment that are optional by others.
Please pick up the phone and call us (301-982-4600) with questions and tech support during normal business hours.
You can send questions via e-mail ([email protected] or [email protected]) and get a reply within 24hours-48hours.
How de we do this? "Purchasing power" and exclusive agreements with our suppliers, we purchase, sell and manufacture more turbo's and components than all of our competitors, this large scale purchasing allows us to buy parts and raw materials at a deeper discount and we simply pass the savings to you.
We have a huge 6,250 sq. ft. facility with a full crew of technical people that love what they do and have no problems helping customers.
We have an in-house Dynojet model 248 chassis dyno to do numerous hours of dyno testing and tuning.
We have an in-house Haas VF3 CNC vertical milling center to make any custom parts that we need.
We believe that everyone that wants and thrives to have more power in their vehicles should not have to go broke doing so.
Our philosophy is when you upgrade your vehicle you do it right the first time and get the "performance without compromise" ... 'nuff said!
The Single Turbo Kits for the 8th Gen Honda Civic Si is comprised of the highest quality components available in the industry. They were designed keeping the end user and installer in mind. The fit and finish of the kit is of superior quality and gives the vehicle a show quality look and OEM style fitment. Installation is a direct bolt-on and takes less time to install than it does to remove the factory parts it replaces. The kits comes complete with everything needed for a successful installation, compare individual parts included before you make your decision.
Horsepower levels range from 350BHP up to 700+BHP, making them versatile enough for any performance enthisiast.
DETAILS BELOWS ON THE CUT KIT:
SRT Civic Si complete bolt-on turbo kit (Shippable Kit, Current built time 4-6 weeks, will be an in-stock item after intro period)
350 ~ 400 BHP
Kit Includes:
SRT custom tubular T304 Stainless Steel Exhaust Manifold
In-house CNC machined flanges for a precise fit every time
thick walled T304 tubing for added strength
unique 4-2-1 design for maximum flow without compromising spool
SRT Spec'd Precision Turbo good for upto 565BHP
Tial 38mm MVS v-banded wastegate
HKS Super SQV (Super Sequential Blow Off Valve)
Stainless Steel braided oil supply line with SRT exclusive oil supply tee
High Temp oil drain line,
Exclusive SRT turbo reserve oil catch can
No need to tap the oil pan
Makes Install a snap and no permanent modification to car
3" High flow lifetime AFE cone filter, dry media w built in velocity stack
Manual Boost Controller (electronic version recommended)
Hondata FLASHPro Engine Management System (Click here for details)
Controls Fuel
Controls Ignition Timing
Controls VTEC engagement point
Increases RPM redline
Controls Cams Phasing Angles
Removes Factory speed limitter
Will come with extremely well tuned base maps
Fine tuning is highly recommended
Seimens Deka 680cc Fuel Injectors Pencil Style
good for upto 450-500WHP (return fuel system recommended for 400+WHP), never have to be upgraded again
Fully Balanced and Flow matched by Precision Turbo
Custom SRT machined for proper fitment in the Honda Civic Si
Walbro® 255lph High Pressure intank fuel pump
All Mandrel bent FULL POLISHED aluminum intercooler piping
Polished is standard equipment for a fantastic show car quality
Bead rolled ends to ensure piping does not pop off under boost
Thick wall design for strength and durability
lightweight aluminum for minimal weight
Huge 24"x 6.4" x 3" Front Mount Intercooler rated at 450+HP
Garrett Intercooler core (no cheap ebay knock offs)
CAD designed and CNC machined end caps for optimized flow
10.5PSI Maximum Boost Pump Gas
Lower compression required above 10.5PSI
Different MAP sensor required for above 10.5PSI
High Temp 4-layered silicone couplers and connectors
4 layers for added reliability and durability
Couplers are Black in color
Stainless Steel High Grade clamps
NGK Performance Iridium Spark Plugs, Colder Level 8
Iridium for longer life and better performance
2.5" Mandrel bent T304 SS downpipe w/flex piece
2.5" High performance test pipe designed not to throw any CELs
All necessary hardware for a complete install is supplied
every single nut, bolt, zip ties etc. is supplied
Original Price: $5,249.99
Winter Sale Price: $4999.99 plus 50% off shipping!
sorry to bump an old thread, this deal is probably expired already, but is there gonna be another sweet deal anytime soon. i want an SRT kit lol
1 - 7 of 7 Posts
