My '06 Civic LX sedan makes a squeaking noise from the front suspension area while braking. It didn't sound like the pad wear indicator, but I took off the pads and rotors off anyways. The driver's side pads were worn down about 90%. I replaced the pads and rotors on both the front driver's and passenger's side. I greased the caliper pins and shims. I thought that might do the trick. I took it for a test drive and the same squeaking noise is there. Any ideas what it could be? It only makes the noise while braking. It's not consistent either, sometimes I brake and there's no noise, but the majority of the time it makes the noise. In the video I say it makes the noise at 35mph and over, but it also makes the noise at lower speeds as well.
I made a Youtube video so you could hear the sound, you'll hear it first around the 0:11 second mark and multiple times after that:
