I'm getting a squeak on each revolution of the wheels coming from the front center bottom the car while on flat surface. All the time. If going very slow it sounds like a slow creak. Hard cornering decreases the sound a bit.
Depressing the brakes does not stop the noise. It does a little bit but I think it is because it decreases the load on the noise spot. I have cleaned and greased the brakes anyway as I thought that was the issue at first. No effect.
I should note the squeaking started after letting the car sit for about a month in the damp weather.
Could it be the front axle? If so what would be the best to spray it with?
