Looking for some help if possible.
I'm having issues with my front springs so hoping someone can clear this up.
Kit # 4.3140
LF part# 257042 4.3140FL
RF part# 249273 4.3140F
Are these the correct part#'s
Thanks!
The top 3 coils are binding and almost touching just sitting...small bumps are(were) brutal.
Ended up using zip ties and attaching a rubber insulator which is a temp fix.
So no one know s the actual part #s?
Sorry I can't help with the part numbers.
The inital coils are most likely going to be at coilo bind or very close to coil bind at rest with weight of vehicle. The initial, lower rate coils, will make the initial jolt of a bump feel less harsh. The downside is coil bind and negative noises that come from such.
