61 - 79 of 79 Posts
love my intake thanks howard for both my intake an the great bbq you all had yesterday was awesome good people good food lots of parts thanks again
Skunk2 - '06-'11 Civic Si Cold-Air Intake
Skunk2 drew upon its experience and longstanding technical partnership with championship-winning Compass360 Racing when developing its all-new Cold-Air Intake for the ’06-’11 Civic Si. The results are the best performing, best fitting intake system available
Fully assembled Cold-Air Intake system shown with the supplied MAF sensor adapter.
Each kit includes a 3.5-inch internal diameter lower tube and a tapered, 3.5-inch to 3.0-inch internal diameter upper tube.
The two piece design and supplied MAF sensor adapter allows for compatibility with vehicles utilizing the factory ECU
A high-quality silicone adapter is included, which eliminates the MAF sensor and supplied MAF sensor connector for vehicles with the appropriate engine management system. The specially designed connector eliminates the step from tube to tube for a seamless transition.
Skunk2’s Cold-Air Intake is manufactured from molded polymer plastic for superior intake air insulation when compared to aluminum as well as for a smooth, continuous taper.
A specially shaped, silicone upper radiator hose is also included with each kit to ensure maximum clearance for the intake tubing and proper fitment.
Each Cold-Air Intake kit includes relocation hardware for the battery, ECU, fuse box, and cooling system reservoir tank.
Unlike other intake systems, only Skunk2’s unique design and brackets allow for the OEM battery to be retained.
Skunk2's carefully positioned tubing and air filter make for an easy installation that doesn't require cutting or modifying of the factory fender liners and greatly reduces the chances of water entering the intake during wet conditions.
How much does it cost? Also how much HP does it give?
61 - 79 of 79 Posts
