1 - 19 of 19 Posts
As the title states, is it possible to put spacers on with your 17" or 18" HFP wheels?? Has anyone done this?? I just want the wheels to be flush with the side of the car. I have both the 17" and 18" HFP wheels and I suppose they have the same offset. Any insight guys? Pics?
:popcorn:
Purpul Plane 4ever!
Im sure you can put spacers on any wheels, just have to get longer studs on anything bigger than a 3-5mm spacer.
I have 3mm on the front due to my camber. Tire would rub on the coilover if I didnt have the spacer.
imo spacers arent worth it if your goal is trying to be flush.
you would need at least 10mm with longer studs. which could cost quite a bit... i think it was about 200 for 4 wheels(canadian).... plus the labour was about an hour each side maybe more depending on how crusty your old studs are (they need to hammer it out i think)....
in the end i weighted the pros and cons.....
pro: flush fitment
con: cost, safety(spacers arent as safe as no spacers, dont let anyone tell you otherwise)... which is a big issue for me.
best bet would be to buy new wheels! cost more but hell... you can sell the HFP wheels, recover part of the cost for new wheels...
:eek:hsnap: oh nice. I have a couple of questions for ya then lol:
1) do you have them on the front and back?
2) how big are your spacers?
3) how much were they?
4) where can I find cheap spacers?
5) any pics?
:popcorn:
i think there only on the back i dont remember i put them on so long ago LOL
there 3mm spacers from what i remember
i got them when i bought my SI wheels
you can find them anywhere or on here alot of member sell em
i dont have pics but i can take some if you would like
Purpul Plane 4ever!
hmm... i might have to run 3mm just because my tires are so close to my shock body.
did you have a good amount of threads left on the stud nomar06?
i got about 7 turns or so on the lugs. you should be fine with 3mm up front, thats what I've had for 2 years now.
My tires are still like 5 mm away from the springs....:giggle:
Purpul Plane 4ever!
5) any pics?
:popcorn:
1. front only
2. 3mm
3. $10 or so?
4. any rim shop that installs wheels
I have camber in the front and rear so my wheels are angled in. Wont look anything like what your going for. If you want flush then buy 10 or 15mm H&R spacers, they run $150 a pair. Might as well but diff wheels with a lower offset.
stock camber for comparison.
1 - 19 of 19 Posts
