21 - 29 of 29 Posts
· Registered
Fellow south americans (not much for sure hehehe) i had this question (i think Wakko can help me):
Finally got to buy my flashpro and im ready to install it.
The only thing is that Flash pro manager, when I choose Vehicle in the calibrations, is giving me 3 possibilities for the South american verision of the Fa5:
-FG2/FA5 Civic si 2006-2011 South America (M)
-FG2/FA5 Civic si 2006-2011 South America (P1)
-FG2/FA5 Civic si 2006-2011 South America (P2)
The first one is giving me only a stock cal, but the other two have identical calibrations (based on the name).
What are the differences between those????
Ive got this calibration from Flashpro Tuning:
- Injen CAI, Vibrant RH w/ HFC, Vibrant Exhaust
This is the closest thing to my setup but its for sure created for us cars. Would there be any issues in using this??
Hi! I have a Civic Si 08. I have a problem with my Flashpro. When I try to lock vehicle to the Flashpro, the VIN doesn't appear and a message shows up. It says that I have to input the VIN number into the Flashpro. Did you face this problem also? How did you solve it? Thanks, Alex.
· Registered
You probably will have to adjust the fuel tabels.
Regarding the the 3 options you get, that´s related to your ECU part number: the brazilian ECU is (M) because it´s part number ends with with M11 or M12. And it´s the MAF calibration for (M) that have only the stock equivalente basemap....but all the MAP calibrations are there.
Theres no problem at all by using the calibration you downloaded....but at the calibration description (I´ve downloaded it to check it out), it says something about RDX injectors. If the calibration was made for those injectors, that´s the reason why you can´t start the car.
If you need anything, feel free to contact me.
Hi Friend! I have a Civic Si 08. I have a problem with my Flashpro. When I try to lock vehicle to the Flashpro, the VIN doesn't appear and a message shows up. It says that I have to input the VIN number into the Flashpro. Did you face this problem also? How did you solve it? Thanks, Alex.
· Registered
Hello, I am from argentina and your problem is the same for all Civic SI from sudamerica.
For solve this problem you must go to the Oficial Dealer Honda and request that save de VIN in your ECU then you can get the access whit hondata without problem.
· Registered
Can anyone in Argentina, Brazil, Venezuela get me a part# for their 2007 and up civic lxs or exs fuel sender unit? sometimes called a meter inside the fuel cage assembly. Please i live in the US and running my car on e85 but it kills the sender unit. Any help would be appreciated Thanks. Honda dealerships here do not carry the part and have no information.
I can paypal you if you can get it and ship it to me- make a little extra cash :) as alot of folks here wants this also.
· Registered
Hello, tengo un civic SI 08 version brasilera, estoy por instalar un hondata traction control pero al ver el ramal de cables de los sensores de abs los colores no me corresponden con los que aparecen en el tutorial de Hondata TC, alquien abra instalado el Traction Control en alguna version SI brasilera que sepa cuales son los colores de los sensores?
21 - 29 of 29 Posts
