Resetting the Power Window Control Unit
with Auto Up/Down Function
1. Turn the ignition switch ON (II).
2. Move the driver's window all the way down by using the driver's window DOWN switch.
3. Open the driver's door.
NOTES: Steps 4-7 must be done within 5 seconds of each other.
4. Turn the ignition switch OFF.
5. Push and hold the driver's window DOWN switch.
6. Turn the ignition switch ON (II).
7. Release the driver's window DOWN switch.
8. Repeat setp 4-7 three more times.
9. Wait 1 second.
10. Check if the AUTO UP and AUTO DOWN functions still work. If they do, the auto function has not been cleared; go back to step 1. If the do not, go to step 11.
11. Move the driver's window all the way down by using the driver's window DOWN switch.
12. Pull up and hold the driver's window UP switch until the window reachers the fully closed position, then continue to hold the switch for 1 second.
13. Confirm that the power window control unit is reset by using the driver's window AUTO UP and AUTO DOWN functions.
If the window still does not work in AUTO, repeat the precedure several times, paying close attention to the 5 second time limit between steps.
