It's not that the engine can't handle the cams, it the fact that the engine can't handle the 9.5k rpm needed to take full advantage of the stage 3 cams. Any engine that can rev to 8k and last 150k miles is pretty effing stout.This is exactly what I was thinking. On a stock block K20 those cams are WAY too much
Tapatalk sucka!
Hybrid Racing, im currently on my 3rd one.I am looking at getting some cartels, did you have the oem tensioner or a aftermarket one?
Or ****ty tensioners.I don't doubt that other cams break tensioners, just seems like more often than not its the s2's, I have heard it is because of the high ramp up design :shrug:
Your just assuming it broke in the conventional way. The last 2 I had blew out the snap ring in the side of the tensioner.tensioners will not break on s2 cams unless your tune is off...
You'll still have a worse midrange than the tuner 2 cams, which make power to around 9k on stock K20s with good supporting mods because the profile is too largeIt's not that the engine can't handle the cams, it the fact that the engine can't handle the 9.5k rpm needed to take full advantage of the stage 3 cams. Any engine that can rev to 8k and last 150k miles is pretty effing stout.
No, it's not that. It's the effect you get of overcamming the engine.It's not that the engine can't handle the cams, it the fact that the engine can't handle the 9.5k rpm needed to take full advantage of the stage 3 cams. Any engine that can rev to 8k and last 150k miles is pretty effing stout.
:yeahthat:Funny Ive been using these cams for quite some time and havent had any issues. The motor has also been opened up and no issues from these cams. Not too mention they put down more power then some other cams people swear by.
Don't believe everything you read on the internet folks. One of the hard things I had to learn during my build. Test stuff for yourself. Speak to people actually using the products.
Skunk2 Stage 3 cams are an amazing product.
<3
