With the ability to adjust both positive and negative camber, Civic owners can reduce abnormal tire wear and significantly improve handling and overall stability.
Skunk2’s ’06+ Civic Rear Camber Kit is a must-have for Civic owners looking to fine-tune their suspension or correct negative camber introduced from lowered ride heights and includes everything you need for an easy, bolt-on installation.
Skunk2’s completely redesigned Rear Camber Kit for Honda’s ’06+ Civic is here. Thanks to Skunk2’s new and unique telescoping, opposing-thread design, camber adjustments can now be made without having to disconnect the arm from the chassis. Simply loosen the jam nuts and twist for easy and fast positive or negative camber adjustments.
Skunk2’s completely redesigned Rear Camber Kit for Honda’s ’06+ Civic is based off of the same adjustable camber kit technology the company’s been using on its own race cars for more than a decade. Skunk2’s ’06+ Civic Rear Camber Kit is a must-have for Civic owners looking to fine-tune their suspension or correct negative camber introduced from lowered ride heights. With the ability to adjust both positive and negative camber, Civic owners can reduce abnormal tire wear and significantly improve handling and overall stability. Each Skunk2 ’06+ Civic Rear Camber Kit is constructed of forged alloy steel and aircraft quality, 7075 aluminum. Each kit includes Skunk2’s industry-leading, low-deflection polyurethane bushings that act as bearings to allow for smooth pivoting without the harsh side effects of spherical bearings. Unlike steel and rubber bushings found in lesser quality camber kits, Skunk2’s polyurethane bushings won’t tear or break free.
FEATURES:
Hard Anodized
7075 Machined Aluminum
Low-Deflection Polyurethane Bushings
High-Strength Forged Ends
Easy Camber Adjustments
IN STOCK!
On Sale $340.00 CAD
