ALL PRICING ARE IN CANADIAN DOLLARS
Skunk2 pro-Series Rear Camber Kits
Skunk2 Rear Camber Kits are a must if you want to fine tune your rear suspension. With the ability to adjust positive and negative camber, you can reduce tire wear and significantly improve your vehicle’s handling. Precision CNC machined from aircraft quality AL7075 aluminum, Skunk2 Rear Camber Kits feature low deflection polyurethane bushings. The bushings act as a bearing allowing your camber kit to pivot smoothly without the harsh side effects of using actual spherical bearings. Unlike the steel and rubber bushings that are found on low quality rear camber kits, these will not tear or break free. The Skunk2 Rear Camber Kit is the perfect choice for street and race applications
06-09 Honda Civic 2dr/4dr....................$350.00
06-09 Acura CSX 2dr/4dr....................$350.00
