1 - 4 of 4 Posts
I installed these today on my si coupe and then took my car to the shop to get an allignment.
The guy then told me i will need to raise my back coils up an inch or so because the size tire and offset of wheel i am running would just rub constanly when he adjusts the camber.
My question is can i adjust the camber arms out a little so i can correct some of the camber(even though its not that bad, and there is barely any tire wear)I would like to do this until i can get 215/45/17 instead of what im running right now 225/45/17
Help pleasee!
thanks but i am gunna wait till i go through these tires before i change tires, i know if i go back to the normal stock size i should be okay.
Can i make that adjustment on the camber arms though?
Hidy Ho Neighbor
Many members will adjust their camber to the negative bias in order to "tuck" their wheels/tires into their fender. Sometimes, if needed, they will also "roll" the inside edge of the fender opening under to make additional room.
1 - 4 of 4 Posts
