Skunk2 Shift Knob
Made from stainless steel featuring a gun-metal finish. Each shift knob is custom-weighted to 440 grams. When used in conjunction with the Skunk2 Racing short shifter, the combination provides the ultimate in positive shift engagement. APPROX. 440 GRAMS
available in 5 Speed or 6 Speed
Christmas Special....$60.00
Skunk2 Dual Bend Short Shifter
Skunk2 Racing short shifters are constructed from high-strength alloy steel for maximum durability and reliability. Unlike even the best aluminum shifters, Skunk2 Racing steel shifters will not break. The added weight of the shifter results in smoother and more positive shifting. Each short shifter utilizes sealed bearings and a low friction coating to ensure smooth motion without binding.(shift knob not included)
Christmas Special....$130.00
Skunk2 06-08 Honda Civic Short-Throw Shift Adapter
Christmas Special....$50.00
Skunk2 Magnetic Oil & Transmission Plug Set
Skunk2 Magnetic Drain Plug Set includes both engine and transmission plugs to help extend engine life by removing harmful metal particles from your engine oiling system thus prolonging bearing and transmission gear life. Skunk2 Magnetic Drain Plugs are designed to racing specifications and feature lightened bolt heads that are cross-drilled for use with safety wire. Skunk2 Magnetic Drain Plugs are easy to install and can easily be cleaned after each oil change. Fits all Honda, Acura, Mitsubishi, Ford, and GM MANUAL transmissions. May fit some automatic transmissions but it is the owners responsibility to determine if product will work for their specific application.
Christmas Special....$35.00
Skunk2 cam seal
The Skunk2 cam seal is precision CNC machined from aircraft quality 6061-T6 alluminum billet and is gun metal anodized for a durable finish. The Skunk2 cam seal features three o-rings for a superior fit and seal compared to the factory plastic seal which has no o-rings. Includes a laser-etched Skunk2 logo design to make the Skunk2 cam seal a perfect addition to your engine along with other Skunk2 accessories.
Fits All B/H/D/F series engines
Skunk2 billet wire covers
Skunk2 billet wire covers are CNC-machined to be extra lightweight. Each wire cover is fully polished and features a contrasting, acid-etched Skunk2 Racing logo. B-Series V-TEC ONLY
Skunk2 VTEC Solenoid Cover
The Skunk2 VTEC Solenoid Cover is precision CNC machined from aircraft quality AL6061 billet aluminum and features a durable gun metal anodized finish.
Skunk2 Radiator Cap
The Skunk2 Radiator Cap increases internal radiator pressure, thus physically raising the coolant boiling point and increasing cooling efficiency.
Skunk2 Radiator Hose Kits
Skunk2 Silicone Radiator Hoses are handmade using high-quality, automotive-grade silicone and feature cutting-edge, multi-layer, embedded fiber linings that’ll resist even the most abusive engine temperatures and pressures. Each application has been test-fitted for accuracy, as well as for an OEM fit, and has been subjected to rigorous tests and inspections to ensure years of worry-free operation. All Skunk2 radiator hoses are compatible with each vehicle's OEM water housings,radiator necks, and OEM hose clamps.
Applications:
S2000
94-01 Integra GSR
Civic 06+ Civic Si
92-00 Civic
02-05 Civic
02-06 RSX
