Skunk 2 stage 2 cams with full valvetrain?
3544 Views 15 Replies 11 Participants Last post by  Skyline4life
Im currently running a DC Race Header, Pulleys, Apexi WS2 exhaust, and an Injen CAI. I've been thinking for a while whether I should stay NA, or go FI via turbo or supercharging. I've decided to stay NA.
Anyways, I did quite a bit of searching, but I still have some questions. Along with the mods I already have, im planning on putting in a set of skunk 2 cams, valves, springs, and retainers. Im also planning on shipping out the ecu to Hondata for a reflash while the car is sitting in the shop, getting the stuff installed. The cam gears will wait, since there is no tuning software out for the SI's yet. What I was thinking was that I'd gain some power with those mods, and the Kpro should be coming out soon, and then my car will be all ready to get tuned.
But my question is, will my car be safe to run with all those mods and no tuning? How much in gains should I see? Finally, what's a rough estimate of the cost of the reflash and the cams and valvetrain, including labor? I usually install parts myself but I wouldn't want to mess with the head.
1 - 16 of 16 Posts
No one is going to be able to answer your questions honestly. There is not a tuning option available right now (Hondata does not offer a reflash for after market cam shafts) so there is no way to know what type of gains you would see OR if it would even run safely. I would just hold off, save your money and wait for K-Pro.
Notes:
Nitrous has not been tested. As ignition timing has not been changed, nitrous is as safe to run with this reflash as with a stock ECU.
Aftermarket cams have not been tested.
Race header / Test pipe. This will eventually give you an engine check light telling you that you have a faulty catalytic converter. We have not seen this error cause any power loss. Race headers are for offroad use only.
For consistency in dyno testing we suggest you follow the dyno procedure outlined here.
those are notes from hondata. if you want further reading... http://hondata.com/reflash_06_civicsi.html
james
also, you don't need to run aftermarket cam gears in our cars. Unless you plan on building a race car they shouldn't be used. I would suggest waiting for a tuning solution.
Cam gears? Our Si's have VTC which dynamically change the camshaft's degree, no ? Correct me if I'm wrong ! :)
I am considering this route as well .
if you do use a cam gear, you only need to run the exhaust cam gear on the k series from what ive read up on so far. i plan on doing the skunk2 head package once a ems comes out already have the stage 2 cams and what not.
are the cams install and what not? How are they treating you?
no there not in yet. im going to just wait to put them in until there is a EMS to tune them with, other wise i think its pretty pointless to install them to just see minimal gains
well i dont thinkt here will be a Kpro version from hondata for our cars. Didn't Doug from Hondata say they had no intentions of making one and that these internet rumors were funny? Iono i hope they come out with our version though
edit: found it?
http://www.8thcivic.com/forums/showthread.php?t=46760&highlight=kpro
We will have some cam tests posted very shortly (next 2 weeks or so) to show what a set of Skunk stage 1's can do with just a reflash. Doug @ Hondata seems to think that the reflash should work ok with a stage 1 type cam. We will post up A/F ratios as well.
In regards to the effect of cam gears...as it was stated earlier, because of the factory VTC, there is no need to run and adjustable intake gear. But even on a set of type r cams on a K20A2, an adjustable exhaust gear picked up 5hp and 3 ft/lbs of torque in the low and mid-range. Im curious to see what playing with the exhaust gear could do on the stock K20Z motors.
I don't quite understnad the graph. Can anyone explain?
Imagine a rollercoaster, the higher the better.
With an adjustable exhaust cam gear installed and set at -2 marks (4 crank degrees) the motor gained 5 hp and 3 ft/lbs of torque throughout the low and mid range (dotted line).
Hope that helps :smile:
Awesome. Can't wait for the graphs for the stage 1 cams.
I can't stand this ****! ima make my own EMS >:{ and make billions!
1 - 16 of 16 Posts
