Skunk 2 RH false advertising...
12K views 182 replies 61 participants last post by  cuzzybubba1
#1 ·
Not totally sure where to put this... but the S2 race header is advertised at a 2.5 collector....
Digitally measured it came out to 2.395 inner dimension and 2.435 outer dimension.
Not that .10 of an inch matters, but isn't that false advertising?
#24 ·
I can't believe this is a thread. The .xx difference will not effect performance. As it stands the skunk 2 header paired with the 70mm exhaust makes the most power of all the bolt on headers out for the car. It was designed to make power and is the only header out right now that compares to a smsp dtr type header.
Somebody else posted they sent a vibrant to be compared. Why? Skunk 2 and vibrant both make good headers and your budget and expectations should be the only real comparison.
Then again what do I know. I just install these parts and dyno them before and after.
#29 ·
No it's not. 2.5" is the nominal pipe size. The nominal pipe size is an approximation of the OD, and the ID is always smaller. Pipe schedule as well as other specifications will result in varying ODs and IDs.
If any of you'd ever had to size pipe before, this would be a non issue.
