CHOO-CHOO!!!!!!
Just got a new product update e mail from Skunk 2. Here it is.
Now Available! New and Improved Skunk2 Pro Series Valves for the B-Series, H-Series, and K-Series Honda Motors
Skunk2 designs, develops and tests all of our valvetrain components in-house to ensure the highest quality and greatest performance gains. During development of the Pro Series Valves, all valvetrain components are tested in engines both on the dyno and on the road. Pro Series Valves showcase new improvements made to the Skunk2 Forged Valves. Manufactured from the best materials available, our valvetrain components provide exceptional performance, reliability, and quality. Skunk2 valvetrain components are standard issue on all the project cars and race cars we build and support.
Skunk2 Pro Series Valves utilize a superior stainless alloy with a higher nickel content than most stainless vavles. They are also heat treated using a proprietary heat treatment process for exceptional strength and durability. Skunk2 valves feature a special hardened tip which will not deform or gall when used with high-lift camshafts. Pro Series Valves are unique as they are precision machined and ground to higher concentricity tolerances which significantly improves sealing, airflow, and stability. Though many aftermarket valves look similar, Skunk2 Pro Series valves feature specially designed valve head profiles to optimize airflow when used with stock or performance valve jobs. Pro Series Valves also feature a block nitride coating on the shaft to reduce friction and wear. To further improve heat dissapation and valve sealing, the nitride coating is removed from the head of the valve. Skunk2 Pro Series Valves are available in stock size s in both high and standard comp. Oversized sizes will be available soon!
One Piece Stainless alloy with higher nickel content
High strength and resistance to premature wear
Proprietary heat treatment
Machined and ground to higher concentricity tolerances which results in improvement of sealing, airflow, and stability.
Specially designed valve head profile to optimize airflow when used with stock or performance valve jobs.
Note: High compression valves increase compression by 0.3-0.5 points by reducing champer valume by 1.5cc or more. same weight as stock valves. Standard compression valves recommended as high quality , direct replacement part. 3-10g lighter than stock valves.
Stock size available now, oversized version to be available soon!
310-05-5310 Pro Series Valve Set B-Series Stock Size / Standard Comp
310-05-5320 Pro Series Valve Set B-Series Stock Size / High Comp
310-05-5350 Pro Series Valve Set H-Series Stock Size / Standard Comp
310-05-5360 Pro Series Valve Set H-Series Stock Size / High Comp
310-05-5335 Pro Series Valve Set K-Series Stock Size / Standard Comp
310-05-5340 Pro Series Valve Set K-Series Stock Size / High Comp
For more information about these new Pro Series valves or any other Skunk2 Products, please click here!
MSRP $238.07
CHOO-CHOO!!!!!!
CHOO-CHOO!!!!!!
I heard there's a new aluminum manifold comming real soon mid spring for our 06+ SI's.
That's what I recall hearing about the composite intake manifold, last year this time.:biggrin:
