1 - 2 of 2 Posts
i have set of sk2 valve springs im currently running tsx cams would this work with tsx cams ? do i have to replace the valve seats can i just replace springs only and run stock cams,tsx cams,and sk2 stage1 cams later. i already have have the sk2 valve springs got them brand new for 100 sealed in box would i loose power later when i put back stock cams
they will work fine...your valvetrain will just have a higher rev tolerance. but you will need new valve seals because if you do the swap, your current valve seals cannot be reused!
1 - 2 of 2 Posts
