Does anyone know if the SI rear sway bar is thicker than the Lx? A worthwhile switch?
sekaisaikyo · Registered Joined Jul 1, 2008 · 89 Posts Discussion Starter • #1 • May 2, 2010 Does anyone know if the SI rear sway bar is thicker than the Lx? A worthwhile switch?
S sir_christopher · Registered Joined Mar 31, 2010 · 38 Posts #2 • May 2, 2010 from what i have gathered, yes, its thicker and you can tell after the install
thunderdome · Registered Joined Jul 12, 2009 · 1,385 Posts #3 • May 2, 2010 yes it is thicker ... and if you wanted more rigidity then you could go bigger then the stock si rsb
sekaisaikyo · Registered Joined Jul 1, 2008 · 89 Posts Discussion Starter • #4 • May 2, 2010 Ohhh thank you very much
W wesuri · Registered Joined May 27, 2009 · 241 Posts #5 • May 3, 2010 I heard your cousin will give you a good deal on the Si rear sway bar. It even includes the sway bar bushings too!
@tomicR18 · Registered Joined Jan 4, 2008 · 1,079 Posts #6 • May 4, 2010 This thread should answer all of your questions. http://www.8thcivic.com/forums/suspension/22930-si-front-rear-sways-dx-lx-ex.html
R randomtask77 · Registered Joined Dec 14, 2009 · 2,370 Posts #7 • May 4, 2010 I did this to my LX coupe last week. One of the best mods I've done to my car. Got the rear sway bar from CollegeHillsHonda.com
ChsKnight? · Registered Joined Sep 7, 2008 · 803 Posts #8 • May 4, 2010 yes this is one of the best and cheapest mods you can do, i love it!!!
