I'm looking into calipers to fancy up the exterior a bit, and I need some help figuring out what I need to install them. First and foremost:
1. What calipers are compatible with our Si?
The Brake Options thread lists the following for compatible brake pads and rotors:
2. What parts do I need to install the calipers?
I don't want to replace my OEM brake pads, rotors, bolts, hats, etc. Do I only need brackets for caliper mounting, and the caliper itself?
Here is an assembly guide for Wilwood's RSX Dynalite Kit. Someone clarify what I would need plz :redface:
http://www.wilwood.com/PDF/ds413.pdf
Thanks! :thumb:
Given that, I believe that any AP1 (00-05 S2000) and DC5 (02-05 RSX) calipers are compatible with the Civic Si. Am I right?Si Coupe Front (2.0) Brake Pads - FMSI# 829
Same as S2000(00-06) RSX-S(02-05)
Si Coupe Front Rotor Options (Same as RSX Type-S, 05-06 CRV)
Thanks! :thumb:
