1 - 20 of 29 Posts
Just had them installed on my LX coupe and they sound awesome. The car now has a nice little growl at idle :) Here's a few pics of the install.
LX and SI Axlebacks side by side
Most of these tools werent even used.. Just wanted to make it look complicated ;P lol Just had to remove 2 bolts and pop the muffler out of the hanger with my bare hands.
To prevent rattling on the springs I used metal clamps.. they worked like a charm!
Closer look
My friend helping mount it while i snap pics.. damn my job was hard :SHOCKED:
And here is the final product (still on stands heh) Easiest mod install ever lol.
PS: Dirty car.. just washed it yesterday, damn that rain! :eek:hsnap:
Thx for looking guys! Vroom :dancing:
Hello again. Were there any complications with fitting the Si axleback onto an LX/EX? I have read somewhere in this forum about the LX/EX having a "pipe" diameter of 1.5" and the Si at 2.5". BTW, is the "pipe" referred to as the midpipe?
Finally, did you simply swapped the axlebacks without having to swap the midpipe as well? Thanks again.
Discussion Starter · #17 ·
There were no sizing issues. Everything fit perfectly and yes I just swapped the axlebacks. Check the pics out lol
Ok, well im a newb but i've been wanting to do this. And i understand this thread is old. First question-what are the springs for? (where do they go). Second question-did you have to use a gasket or anything? Thanks in advance
Discussion Starter · #19 ·
The springs are used to connect the axleback to the exhaust along with a bolt. Im sure someone on here can explain it's purpose better though lol.
As for gaskets, its recommended that you change them but since my car was relatively new, I just used the stock one and has been fine for about 6 months.
Nice Job. i put the HFP on my lx but took the springs off and used washers and fits perfect.
put those springs back on and keep 2-3 washers in there to keep it from rattling. you need those springs to keep the gaskets sealed and unstrained from the midpipe to the axleback. the purpose of the spring is to keep the exhaust bolts on tight enough to seal the exhaust properly while it allows enough play between the two pipes (the mid pipe and axleback input pipe) so that the flanges (where they bolt together) will not develop cracks or tears around them (which is otherwise known as exhaust leak).
1 - 20 of 29 Posts
