1 - 20 of 55 Posts
I'm looking for a shift point at peak HP, on my stock motor and it's never been flashed. I've dyno bikes and some bikes the peak HP are 500 or 600 rpm's before redline and some pull up to the redline.
To reduce confusion: Please only reply it you've had your car dyno'd or hang out at a dyno shop/race shop.
To reduce confusion: Please only reply it you've had your car dyno'd or hang out at a dyno shop/race shop. image
100% stock i think peak HP is at 7800 rpms
Shift light comes on around 8,250 RPM's, got it.
Can the factory shift light be changed to a different shift point (RPM)???
shift light starts blinking a little before 8k i think....maybe 7600.
goes solid at 8k.
fuel cut off is at 8250
not sure if the light can be changed, but the redline can be changed with flashpro.
Discussion Starter · #9 ·
It makes zero sense to over rev a motor. Shifting at precisely peak HP will yeild faster E.T.'s.
I may looking into the MSD shift light.
Well...it depends.
What yields higher ETs is maintaining the most power to the wheels for the longest time possible.
This all depends on the gearing of the transmission.
the reason you shift past peak is because you want to stay in VTEC for maximum power unless you have fp.
Discussion Starter · #13 ·
Let's stay on the thread topic.
When you dyno'd your vehicle (w/ criteria above, stock motor etc.) at what RPM did the printout show peak HP?
wouldn't it make sense to go as close to fuel cut where a decent amount of power is still being made so that you land at a higher rpm and will be making more power then shifting at 7800 and landing in a lower RPM and thus making lower power
Indeed it would.
OP is ignoring gear ratios, however.
Discussion Starter · #18 ·
I view things this way... if you like to shift your vehicle sooner or later... that's cool!
It's all about what works for that individual.
as long as you fall back into vtec after your shift your fine. This motor is based on rev's rather than utilizing peak torque and such.
1 - 20 of 55 Posts
