1 - 9 of 9 Posts
I've got a set of S2k horns in my garage. I'd like to install them in the Civic. Has anyone done this? I'm hoping the connectors would match up and just be a simple plug and play.
the horn is in the front bumper area - directly straight ahead of the driver's seat.
there is one horn fed with a single positive lead wire, so if you're connecting two, you'll have to do some tapping/splicing. I just used the original bolt area as the ground (as did the stock horn)
Discussion Starter #6
Got S2k AP2 horns installed today. After the bumper is removed you can see two horns. It was a 10 minute plug and play install....once the bumper was removed of course.
Discussion Starter #7
I removed two horns, one located as you described and one in front of the passenger seat. Maybe it's a MY2008 thing?
Binks
i thought the civic only has one horn. how much better is the s2k horn compard to the 'road runner' beep?
Discussion Starter #9
Definitely two horns, which made it alot easier for the install. If there was only one horn I would have to tap the horn wire to install the second horn (S2k uses two horns) and find a place to mount it.
It's much better than stock. Very loud. It gives it what I would describe as a european sedan tone. Completely satisfied :thumb:
1 - 9 of 9 Posts
