1 - 1 of 1 Posts
Ive done some searches and found out most of the things I needed to know. BUT...The owners manual says to use Honda MTF of course and then after says you can use motor oil that has an API seal "for gasoline engine only" as a short-term fix and prolong use will cause harder shifting. How long is too long to go before changing the motor oil in your tranny?? And also on the API seal on the 10w-30RP bottle says ENERGY CONSERVING,is it still ok to use?
1 - 1 of 1 Posts
