1 - 9 of 9 Posts
I found out this morning from a guy I work with that both of my reverse lights are not working. I have not had time to check them since I have been working a lot more. All off my headlight and everything up front still work. So does everything else on the back. I would normally think its the bulb's but I have never had the same two bulbs go out at the same time. I will check them if and when I ever get another day off.
My question is are the reverse lights on a fuse by themselves? I am just trying to have some other areas to look for the problem if the bulbs aren't burnt out.
I have an 08 si coupe.
Thanks for any info.
Discussion Starter #7
I do not think it's a fuse. I pulled one of the spare fuse 7.5 from under the hood fusebox and put that one in and still no lights. I will now check the bulbs and housings when I get to the auto store to get bulbs. I will keep you guys posted.
1 - 9 of 9 Posts
