1 - 2 of 2 Posts
I've had the HFP on my car since about 10'. And I'm pretty much over the stiffness and bounciness of the HFP.
Going back to stock, I know I would need the stock coils for the rear(which i think i still have).
But far as the "SI" struts/shocks. Is what autozone/etc lists for the 2008 'SI' the correct ones of the actual SI? Or are they just the generic OEM ones for the civic?
All 8th gen coupes have the same suspension, shocks/struts, springs, etc. The Si sedan shares the coupe's suspension.
It is only the non-Si sedan that is different. And even then, they are completely interchangeable. The only exception is the front struts, where the spring seats are different, but a complete assembly will swap over with no problem.
So, if they have separate part numbers for coupe vs sedan, then you will have no problem. Just get the ones that say coupe.
How many miles have you put on your HFP kit?
1 - 2 of 2 Posts
