1 - 10 of 10 Posts
Hello..
My si has 110k and the clutch is working fine. I wanted to know what would be a upgrade to the stock clutch when I replace. Just better performance not to crazy. Thank you all
OEM replacement Exedy also works with full bolt ons. Lasts longer too. It depends on what mods you have planned. I’m running a 11.5lb lightweight flywheel and it helps me get into the power and sooner. Running OEM Exedy clutch as well with HR CAI. Zero problems. ??
06FG2 736.72whp/[email protected] e85/ FA1-R18 Daily FTW
Like stated before it depends on your overall plans with the car but if you're just doing bolt ons then a stage 1 or 1.5 is fine. I would get a lighter flywheel as well
Discussion Starter · #7 ·
Do I have to buy a separate flywheel or can I purchase one with the new Exedy clutch?
Discussion Starter · #9 ·
I believe Exedy has a kit with flywheel included
Sweet.. So the oem kit is $377.. And the stage 1 kit is $364.. I have a intake, throttle body spacer and skunk2 muffler on now. Will probably get hondata when I can afford it. What would be the better kit for my car if that's all I'm probly going to do to it.
Discussion Starter · #10 ·
Also watched a video that said I should do the em2 cmc.. is that a necessary part as well?
1 - 10 of 10 Posts
