I have a 08 civic ex, and a little while back I started getting some problems shifting, I had to press the clutch all the way to the floor basically and get my rpm’s up to shift smoothly. I thought it could be the clutch but there was no slipping etc, so I ruled that out, then I started with bleeding the clutch to see if that worked. It did… temporarily, then back to its normal bs. So I replaced my clutch master cylinder and once again filled and bled the system, and it still felt soft and wasn’t shifting right. So I adjusted the clutch pedal to have a longer throw, and it still isn’t shifting correctly. Is there anything that I could be overlooking that could save me the time and money of replacing the slave cylinder or the lines?
