1 - 1 of 1 Posts
Vendor
If your engine started to overheat, you've noticed the changes in performance and your sensors let you know that something is wrong with the catalytic converter - this problem should be resolved as soon as possible.
Eliminate the risk of getting high fines and stop spreading the harmful emissions into the atmosphere by having your heat-damaged old catalytic converter replaced. All catalytic converters showcased at CARiD are engineered to meet or exceed required emissions standards and are designed for long lasting durability and performance. CARB compliant applications are available as well.
Reduce the number of harmful emissions your vehicle produces, by making it a little bit 'greener' - install a custom fit or universal converters from CARiD today. Browse through the complete selection of available options here.
1 - 1 of 1 Posts
