I just installed the progress rear sway bar and redshift reinforcement brackets. I was just wondering if anyone else had a hard time getting the drilled holes to line up. I had to use a 3/8inch size drill bit to wallow the hole out enough to make it line up. My main problem was getting the drill into position to drill in the exact location. I was off by maybe 2mm.
Anyway I was concerned that this would have weakened the use of this bolt but I see that from the design it really shouldn't matter.
So I also took some nuts and washers and placed them on the back side of the supplied hex bolts as a double nut if you will, on the back side of the plate. I figure this is ultra strong and I was thinking of welding on top of that but this metal is so thin I would hate to burn through it with my MIG welder. PS. Huge difference the car finally rotates and sticks easier. :woot:
