1 - 4 of 4 Posts
pic borrowed fm Daryl Nilsen with thanks (not the yellow circles)
but the black strip between bumper and fender
Any guy can shed some light on the above removal
i hit my rear bumper and broke the side spacer too
now need to replace else it protrude out abit
thanks for the advice
Prolly need to rplace the bumper if the peice that you are talking about is the hole on the corner of each side that a bolt goes thru with a washer sorry can't be any more help. Good luck
I found the method removing the spacer
simply access from the trunk via removing the black covering beside the rear lamp area
there you'll see the three white plastic square nuts protruting
press the locking catch and push forward, the spacer will just drop out
remember to remove the screw on the last nut
Thank you for posting and especially closing out your post. I had the same question on a different Honda, and this was the first result on google. Well explained and confirmed my suspicions, really appreciated the detailed response to your own question. Have a fantastic day!
1 - 4 of 4 Posts
