I just installed tein lowering springs and added the rear SPC camber kit. i went this morning to get my car aligned and the rear driver side camber was adjusted to 1.8 degree negative camber but the passenger side camber wouldn't move. it just stayed at a -3.7 degree camber. i noticed that when i did the install the main bolt that goes in between the bracket and the control arm were facing two different ways. The driver side had the bottom of the bolt next to the spring while on the passenger side had the bottom of the bolt away from the spring. Does having that bolt facing a certain way make a difference? Or do i just happen to have a bad set of SPC Camber kit?
