1 - 2 of 2 Posts
So I've had this problem for a while now, and I'm not sure what's causing it. I have the stock radio installed still and everything is working fine. But every now and then when I roll down the window on the passenger side the rear channel goes out. Same with the sub...
Then I discovered that it will also do it some times when you use the power locks. It's pretty random when it does happen, then I figured out if you just turn off the radio then turn it right back on it'll be working fine.
So it seems like something is shorting out the stock amp from within the passenger door. Any clues? Thanks!
1 - 2 of 2 Posts
