401 - 403 of 403 Posts
Seems like for most people the boomba mounts/dampers eliminate wheel hop. I have these and i still got a ton of wheel hop at the track. However, my motor was recently pulled to install a clutch, maybe they didnt bolt it back in tight enough? i checked all the boomba mounts and they are all tight...
Discussion Starter #402
Other variables can induce hop. The OEM front lower control arm bushings are soft enough to induce hop.
Solution: Poly, or spherical LCA bushings. OEM strut dampening won't help much either.
I take it the hasport mounts became its own thread? I was waiting for some comparisons in this thread, but none the less good information. It is such a shame the mounts wore off so fast. I'm unfamiliar with motor mounts, do stock mounts wear out the same way as well? From this thread so far, innovates 75a seems the best. I was planning on throwing on a KW kit. Any other ideas of supporting mods I would need?
