6-OCT-2011 Update: Spreadsheet uploaded to web file host. File is NOT zipped. This should finally fix all issues that we have been having viewing the spreadsheet.
Link here: FileSwap.com : Boomba_Innovative_-_8thCivic_Collective_Comparison(30-JUN-2011 Update).xls download free
If anyone has any further input (especially on the Innovative and Boomba *MOTOR* mounts), feel free to post here/leave a comment on my page/PM me, and I'll update the spreadsheet as neccessary. The more, the better.
(Spreadsheet attached below.)
:usa:
Fellas/Chickas,
I know alot of us are having a hard time deciding which mounts might suit each individual best.
I think this will help us ALL compare one against the other (Innovative vs. Boomba), help those buying mounts decide which ones are right for them, and help those with existing mounts (aftermarket/injected) decide whether they should change/upgrade.
So how 'bout this - Lets use a 5 point scale - (Mind you, this should be judged AFTER break in)
*Vibrations
5 = rattles your teeth out - 1 = like stock
*Wheel-Hop
5 = non-existent - 1 = crazy stock hop
*Shifting
5 = shifts flawlessly - 1 = grinds or locks out like stock
*Grounds
Yes/No = Was relocating/rewiring grounds neccessary?
- ALSO -
If you have the Innovative mounts be sure to include the polyurethane stiffness rating (i.e. - 60A, 75A, 85A, 95A) in your post.
If you have the Boomba mounts be sure to include which set you have (Motor mounts (driver/passenger) or Torque Mounts (top dog-bone, bottom dog-bone, and front))
UPDATE: Please include ALL pertinent horsepower mods as well - Realxlai brought up a good point, that those boosted (or those who have high horsepower NAs) may experience differences in performance from mount kits, which may skew results if not noted.
I think this will only work if we can get as many people's input as possible. I'll average the results out once we get enough input to make a good comparison.
Thank you SiVtecBoi80 for kicking this off for us!
:usa:
Fellas/Chickas,
*Vibrations
*Wheel-Hop
*Shifting
*Grounds
- ALSO -
Ill start with my innovatives.
Vibrations = 2
Wheel Hop = 4
Shifting = 4-5
Mind you I have the 60a setup. So vibrations are minimal, shifting is much improved im sure a 75 stiffness would make shifting even better but at the expense of more vibration.
I would never turn back this is how the car should feel from factory. I have had the innovatives for a good 3 months or so.
When first installed the vibrations were more noticable but it definitly broke in after a month or so. The vibrations are felt very little in the wheel with the a/c on or upon take off in 1st at a low rpm. Its minimal to the point you really have to focus to notice it. Vibrations are far less than my powerstick and my torque damper I had before.
