Radio help
415 Views 18 Replies 4 Participants Last post by  RyanJack
Hello. I'm not really sure where i would put this. Or, specifically where I might find the answer. There's just so much info, it's overwhelming. Anyway, I have a 06 Civic LX. I bought one of those Chinese made android headunits. The factory stereo doesn't have BT, and i thought it would be nice to have a few other bells and whistles. It sounds ok. But, there's no power to the speakers. What I mean is, I can have the volume maxed and its still really quiet. I thought about upgrading the speakers and adding an amp. But, for starters, I don't know if that would even fix the problem. Second, I don't know what to get. I'm not real savvy in this. And I don't have a lot of money. Can anyone recommend a good set that is fairly affordable that would work so I can hear the stereo when I'm actually driving? I've looked on FB marketplace, and I've seen 2 channel amps and 4 channel, etc. Not sure what to get. I also don't know if I would need to add a battery and everything that you see when people really get into it.
1 - 19 of 19 Posts
When you bought it, did your factory radio have an amp? If not, is the android radio made for Civics with an amp? Those Android radios can be tinkered with, have you checked any menus in the settings for this? I doubt an amp and new speakers will solve your problem. Anyway, if the radio was made for a factory radio with an amp, then all you need is a wiring adaptor, at least that is my understand when I researched a radio like this for me.
No, I don't believe so. I didn't see any when taking everything apart to install the new stereo. The android unit was from Amazon. When I go into the "hidden settings", I think there's an option for an amp. But, I'm not totally sure. As for the adapter you are referring to, can you link an example? I'm not sure what you are talking about.
Thank you. I didn't think so. With that said, what can I do to improve the sound?
Most likely it should work if installed correctly.. The factory setup, assuming yours was factory and not modified/tampered with by previous owners, should be a connect and play.
The factory setup is pretty basic 20-40 watt system, with 4 ohm speakers. does the new unit have any setting or switchest o change output for 4/8 ohm outputs.
If you already have it installed, you or someone either used a harness/adapter orcut and spliced wires. If wires are spliced I'd check all the connections where the splicing was done.
The adapter referenced above would be like below, made to allow a new radio/headunit to be installed without cutting factory wire harness.. solder is best connection, but connect color coded wires to new radio and plug into factory wire harness.
I do have the harness adapter. And, I'm fairly certain I installed everything correctly. The volume, even when maxed seems a bit quiet. I like the unit well enough. It's just that I cannot listen to it while driving at speed. The road noise muffles the sound. And, there isn't too much of that to begin with. Maybe I should look at soundproofing?
I listen to mine. but its an '08 EX cpe w/ factory amp "Premium Sound", at 80+ with a canoe or kayak on the roof. From what you are saying it would tak a lot of sound proffing the external noise out to make that kind of difference.
With the non-premium systems the wiring is pretty much run direct from the head unit to the speakers, maybe one more connector between... but if it worked before its not likely it just came loose.
How was the volume with the factory or previous head unit ?
What radio did you buy ?
I listen to mine at 80+ with a canoe or kayak on the roof. From what you are saying it would tak a lot of sound proffing the external noise out to make that kind of difference.
I'm just trying think of anything I can do, aside from getting a completely different unit.
I picked up a cheap Android headunit from Amazon.
In other news, I checked the system again. It looks like the unit has outs for an amp. But, I know my stock system didn't have an amp. Can anyone suggest options? I was thinking I could solve this by just getting an amp. I would use the stock speakers to save money. But, I read that the wires in stock are not super. So, the amp would need to be small. I believe 75 watts is what I saw. I am not an audio guy. So, I don't know what would be good. Or, is there some super budget kit option? I imagine this is very straightforward. But, it seems I need to make things hard for myself. Also, while I don't think she has a factory amp, she does have 6 speakers, instead of 4. I don't know if that would make a difference anywhere. But, there it is.
When you say 6 speakers, some Civics w/o the Premium amplified upgrade did have 2 twwters plus 4 speakers I believe.. the twwters are just wired into the front L & R speaker outputs.
The cars with the Premium System have 7 speakers, adding a Sub-Woofer.
Did the original system sound ok, and have the volume level you want to achieve.
Your original post did not say, if just said you wanted BT option.
Many guys have made that change, factory to inexpensive Andriod type systems, some with your setup, and soem with the premium amplified systems,, there are many post about it around.. but most sucessfully solved.
Without knowing what you actually bought there is no way for anyone to tell you what it can or can't do.
The speaker wiring itself should not be an issue.. you should worry more about the factory speakers if you go the rote of just throwing more money at the problem adding an amp which perhaps my not be the problem... get some hands on advice from someone who knows a little about auto-stereo systems.
The original system had decent sound. If it had BT natively, I would likely not have tried to swap. Every BT dongle or plug in I've tried sounds like crap. So, I thought I'd try a system with everything. I did pry up the covers on the tweeters. They look wired simply. So, I assume mine is the 6 speaker non premium system. I did update my last post, though. I was able to plug in something with RCA outs to things. So, it looks like the headunit could support an amp.
So if the speakers worked before and you wired the new unit correctly it should work. Unless perhaps the new unit just has a much higher output and blew your speakers by over driving them.
What unit did you buy and install ?
The RCA out puts would go to an external amplifier, and then wire the outputs of the amplifier to the speakers.
If I was going to go that route I'd eliminate, or ignore the tweeters, and replace the 4 x 6.5" speakers with a better set of speakers like the Polk DB652 for a better sound.
My guess, not relative to the current issue is your esisting speakers have exceeded their life span and need replacing either way, Those doors are know for getting wet inside.
The speakers still work, I guess. The just are much quieter than with the stock system. But, it sounds like you're saying getting an amp and better speakers really is the way to go.
I don't think I'll end up with the factory unit back installed in any case. So, having better equipment just sounds like a good idea. I'm not looking to blow out any windows. But, are there any suggestions regarding a good budget amp that would allow me to hear the music even with the windows down and driving? There are so many out there with so many different output strengths. I don't know what is right and what would be overkill.
It all starts back at your HeadUnit... and ends at the speakers.
What capability does the Head Unit provide ?
2 Channels, 4 Channels, Sub-Woofer and go from there.
Unless you bought a really cheap crappy unit they loudness should not have diminished if installed correctly.
You could go on a place like the Crutchfield web site, not amazon.. you can find information that is helpful. as well as enter your cars specifics, and search for audio components, head uits, amps, speakers and they will list items that are compatible as direct fit components...
If you want an audio system that works you need to know a little about car audio,have some mechanical and electrical ability to do it yourself.
This is from the listing. It's a podofo 10.1in headunit..
So it claims to have 4x45W outputs, which is about the same output from the factory head unit.. sound level should be similar. Problem with those cheap electronic products is there is little or no real technical information about them.
I've looked and have never been able to actually find the technical documentation for the factory HeadUnit or Amp used in my '08 Civic either, but have read most every post on the web I could find over the years.
I assume you wired it based on some document you got with the Unit or the adapter harness..
Yeah. I just plugged in the harnesses that were provided with adapters. It really was plug and play.
1 - 19 of 19 Posts
